indution kit
yeah, one of the aftermarket "gives you 40hp!, never needs washing! made out of silk and gold!" panels
K&N , ITG or similar
K-Tec/Piper X filter in standard airbox, everything else is a waste of money,
and thats coming from a man that has the JMS V6 setup.
You can add a 90 degree silicon hose with an oil breather to the standard box and ditch the acoustic valve,
then you've got the best airflow possible out of the stock setup.
i would stick with what renault gave you..
however if you are interested - i have a K&N cone only you can have for £35
Not worth it you could get heatsoak with an open cone and you could just loose power which im sure u dont want, stick to what you've got and stick an aftermarket panel filter in there.
I was told to just whip the AV hose off and tuck it away, where is tha AV'ed hose feeding from?
This ^^ and remove the top cold air feed if you want some more induction noise.
