depends how much trashing you give the car. Track days cars it would be worth changing more often. Every 2 years I do now, depending on how many track days I've done. It's cheap to do, and quick, so why not? Especially as the JC5 does like to fall to bits
Level check, all you do is remove the wing nut on the front of the box when the car is on the flat. The oil should be up to the bottom of the fill hole.
