I've had a search but can't see anything. What size resister is needed to switch the light off when the canister is removed?
I understand some people never get the light on however I did within 10 minutes.
I decided to remove it due to it starting to make a loud ticking noise, since the light has come on the car now feels sluggish, I hope it's fixed by fitting a resistor!
I joined my 2 pipes together at first but found idling erratic and the engine stalled after a couple of minutes. I've now plugged the pipe going to the inlet plenum and left the pipe going to the fuel tank open to the atmosphere. As for the valve on top I have just left the wires attached and tie wrapped it to the bodywork behind the headlight. You can of course remove the valve and put a resistor in to stop the engine emmision light coming on. Don't know the resistor value but someone will advise you later on this thread.
I got rid of my canister today i blocked both pipes off close to the fuel tank and the other next to the inlet, and removed the excess pipes/clips.
I left the electrical plug connected and cable tied it near the headlight all done while i disconnected the battery, after reconnecting and starting it i had no extra lights on.
Have you tried disconnecting your battery for 10min it might clear the fault, if it doesn't work defo a diagnostic jobby.
