Boot won't open!!
  '03 MCS, MKV Ed30
My boot wont open when central locking button is pressed on remote/dash. Ive read its the solenoid on the boot catch, how the hell am i meant to open the boot from the inside to change it?
Also how much am i looking for it to be replaced?
Thanks
James
  RS6 C7
This will be fun :p , Climb into the boot and take the plastic cover off the boot lid and see what you can see? Maybe there is a catch but im not sure ;(
Struggler
  Ph1 track 172
climb into the back and use a tx15 torx bit to take the boot plastic off,
then there should be a vertical 2mm bar running from the boot button to the push the bar down as far as you can, and t he catch should pop!!
then change the solenoid!
  '03 MCS, MKV Ed30
Just don't use the boot ;)
I haven't been doing since it stopped, just wanna get it sorted really.
Thanks mate.
  '03 MCS, MKV Ed30
Renault have told me the Solenoid is part of the handle so i need to buy the assembly which is £43?!
  BG 182 FF
Yep, about £45 quid as they only sell the solonoid unit complete. It's almost definately the motor that's packed up. You can buy these on their own on ebay for about £15 though
  '03 MCS, MKV Ed30
Already ordered the Solenoid from Cliospares so will replace that first! £25.50 with CS Discount :D
  '03 MCS, MKV Ed30
Ill update this for anyone searching and getting the same thing as I did.
Took about 5mins to swop the Solenoid over and has worked fine ever since.
