"STOP" & "Brake" lights intermitent when turning at high speed
Car  '03 MCS, MKV Ed30
Simple wiring problem?
Also my horn has stopped working, easy fix once airbag is off?
Thanks
James
Cool thanks guys.
Theres a weird squeaking noise coming from the driver side front corner too so maybe thats the pads wearing through?
^they don't have wear indicators, the low brake pad warning is caused by low fluid, because all the brake fluid is in the calipers rather than in the resivoir
new pads and check level AFTER
Nah i meant the bit of metal that can touch the disk and make the noise hes talking about
Are you sure you dont have my car as it has all the same problems as mine :/ apart from your aux belt is probably still in 1 piece unlike mine :(
Got new discs and pads ordered. Just need to sort some decent brake fluid if anyone knows best to use?
Thanks.
