Central locking only works on dash button (52 Plate 1.2)
Car  '02 1.2 Dynamique
Hi guys.
Just picked up a 2002 1.2 Dynamique. I was aware that the remote central locking didn't work when I got the car (presume both batteries are dead, LED doesn't light on the key when pressed).
Is it normal that when I manually un/lock the drivers/passenger side door that it doesn't toggle the locks on the other doors? My old car had a sticky motor, so I used to manually lock the drivers side door and then that would send a signal to the rest of the locks - and they'd lock too.
This doesn't seem to happen on the Clio.. seems like a fault to me. Is it?
I was told to get the keys re-coded, it's a dealer only job and is going to cost me £75. (The batteries have been flat for ages, so presume they'll need coding).
change batterys, check to make sure microswitch on circuit board inside key has not come away, if it has re-solder it.
We code keys and we are based in Portsmouth if your local.
I have had the keys apart now, and the battery had come unseated slightly. Clicked back in and all working now.
Is it normal for manually locking the doors to not trigger the central locking though - as I said, that sounds like a fault to me!
