what torque to use on wheelstuds?
use locktite on the stud into the hub, but not on the nut. Stud does not need to be very tight into the hub, just nipped
You can tighten the nut onto the stud to a higher torque than a wheelbolt. First check if the manufacturer has a suggested torque, if not, I would suggest 130Nm on a clio
They are a parallel thread anyway,just locktite the end and put them in so they sit flush with the back of the disc.
