How would u do a front headlights conversion
Car  1.2 daily +172 ph1
As said above if I was able to do a face lift conversion on a ph1 to a ph.
How I mean by this is to do wiring loom difference between a ph1 front headlight connexions to ph2 face lift ?
Just wondering if anyone can help thanks
to chagne ph.1 to ph.2 headlamps?
I'd have thought hacking large lumps out of the bodywork will be the biggest challenge
This. You'll need a new bonnet, new wings, new bumper and probably some other stuff as well, before even thinking about wiring stuff up.
Aye wiring looms are the least of your worries when you've got a slam panel, front panel and possibly inner wings to change along with the whole front end.
Inquestion is I have a project car for track use. And I'm running a ph1 172 sport in to a non sport ph2. The connections are different every where so I have had to connect up engine dash and rear loom in to make it a ph1 setup in a ph2.
My problems have been little so far. Engine and all loom is in but have not powerd it up yet.
