Clio 172 ph2 / bikes
Hi guys, wondering if anyone has any insight.
Just finishing up a brembo conversion on my ph2 172 (non cup with abs) and whilst i appreciate you get away with the standard master cylinder i know from experience with building bikes how much difference in feel a master creates. It's not something you can appreciate until you've experimented with hydraulic ratio in both directions i reckon.
Anyway, i was under the impression you can use the 197 master as a straight swap in conjunction with the 172/182 servo. Can anyone verify this?
I'm going about the master situation a little creatively which i'll explain once i've verified it rather than muddy information on here.
Currently, i've thoroughly power bled the system it holds pressure on the bleeders guage, doesn't leak but pedal falls to the floor as if systems open. So either there's a stack up height / stroke issue in relation to servo or the 2nd hand master I've used's seals are gone in spite of basic bench testing. Likely both knowing my luck.
I can refit the 172 master in the meantime whilst i inspect however if i'm upgrading the master... I don't want to do this job a 3rd time so any insight is massively appreciated.
