Products to protect red paint?
I think most waxes and sealants have UV protection in them. I don't think there needs to be anything else added.
Cheap good examples:-
AG HD wax
Zaino Z8 sealant spray
Either onevof the will give you protection from the UV rays just re apply them now and again.
Red? LOL!
We both know it's PINK!
Also, you can borrow some of my HD wax if you like. Doesn't take much out of the pot for a layer!
AG HD wax
Z8's the easy spray on wipe off stuff isn't it? Just apply after a wash?
I'll grab some of that I think.
I'm pretty sure Gally started a thread about the protection of the trophy paint. I'll try and find it.
Yeah.
Werkstat Jett is a good protection spray not to sure if has UV protection in it though.
AG HD will give longer protection over the Z8 if you don't want to apply every 6-8weeks.
Forget the Z8 it's more a finale top up product. It's immense but it's a show spray imo.
Werkstat is the easiest sealant to use. 2-3 layers and it'll not only look immense it'll protect.
Imo Z2 is one of the best because it's stronger than normal waxes.
If you really want it protected get it corrected a little and get some Gtechniq C1 applied. That's the only product that i'd be confident enough to apply and not have to worry about.
http://gtechniq.com/shop/3s-for-cars/exterior-coatings/c1-crystal-lacquer/
That C1 doesn't even have a price by it!
Cheers for the advice, I'll have a think about them. Hopefully gregs going to machine polish it then I want to seal it so need something in the next couple of months.
Haha. It's for professional use only but I could get you some. It's about £60 for a 15ml bottle iirc.
The bottle would do 3 cars probably. Although it'll last 2 years if washed correctly.
I personally would look at sealants instead of waxes. Just so you know.
Wekstat Jett or have a look at the Z2 system by Zaino. :)
Forgot about cyc selling it.
Infact i'll find Mat's Trophy thread after lunch.
Am I right in thinking most waxes and normal sealants provide little UV protection to stop fading? Apart from the nano type sealants of GTechniq, CQuartz etc
I have a red car, tbh i didnt even think about fading when i first starting getting into the detailing scene. I do have Werkstat though so that covers me for that one.
Vics concours would look lovely on your thophy imo. Durability wise and UV wise not very good, looks wise brilliant.
Carlack nano, I like using it on plastic headlights, keeps the UV from damaging and going misty/crap looking
Werkstat Carnauba is incREDible.
I've been using it this weekend.
(Lame phone camera)
This is after one coat. I thought 'meh, it doesnt add much to the prime'. But now with every subsequent layer it gets even glossier and deeper. Should have about 6 coats on it by the time I have to drive it.
That's what it's all about mate! Layers!
Looks immense mate.
Don't the kit mate glos is not needed imo. Better top up sprays out there.
Get the acrylic one. I only say this is because it's more durable. Carnauba will look better but only marginally.
Drastically more durable?
I doubt it will make much difference if I can get the layers into double figures...
I'd probably say in Mike's case where he probably isn't polishing and waxing all the time, to go for the more durable one.
Ease of use is hard to beat otherwise i'd say go for AG HD or Z2 as they are more durable but not quite as easy to use.
I'm just lead to believe by PB that for durability acrylic is a little better, the reason being is it's based on Carlack's products so the Carnauba one is more for looks on flat colours.
Either or is fine and once you get layering it'll probably be fine, peace of mind I usually suggest acrylic.
Cheers JD, was waiting on you popping in. Acrylic is very slick especially on prepped paint. :)
Wuv woo!
(Lame phone camera)
That looks so shinney :D Might have to give it a try. Could you get some better pics up sometime too please, might sway it ;)
After several coats. I fell out with carnauba at first as it dried very quickly, leading to a re-correction of the bonnet.
I can imagine that tbh, although its been perfect working in my garage in this temperature.
Mild, agreed. I stupidly did it during a heat wave, granted out of direct sunlight but it was still jolly warm.
