Brake fluid HELP?
I have bought a 500ml bottle of motul rbf 660 will this be enough too replace the old fluid with?
The system holds 700ml , you should be ok with 500ml but i'd get 1 litre if i were you just to be on the safe side . Just bleed it through til all the airs gones , half a dozen pumps on each caliper is usually enough to expel any air . Never completely empty the system as it fcuks up the ABS .
Okay thanks for your help hopefully be able too get some before the weekend lol.
