SuperJ Car Abarth 595 Feb 8, 2012 #1 Have changed the bulbs in both but they still dont work. The indicator and reverse lights work fine. Any ideas what it could be?
J James28 Car RB 182 Clio Feb 9, 2012 #2 Dodgy connection most likely. Common problem being a dodge connector, more common causes the lights to flicker. Unplug the connector, clean the pins with WD40/tooth brush, check the earth connector (inside boot just below hole wires pass through) Failing that check fuses.
Chapster5 Car 2009 1.4 Astra SXI Feb 9, 2012 #3 Just a quick thread HiJack... Should both sides of my car have Fog lights? on the rear? Mk2 Ph1 2000 1.2 8v It has a bulb drivers side just not passenger side? Nick
SuperJ Car Abarth 595 Feb 9, 2012 #4 James28 said: Dodgy connection most likely. Common problem being a dodge connector, more common causes the lights to flicker. Unplug the connector, clean the pins with WD40/tooth brush, check the earth connector (inside boot just below hole wires pass through) Failing that check fuses. Click to expand... a bit of WD40 worked a treat, cheers man.
