Rear fog and brake light wont work on drivers side.
  Abarth 595
Have changed the bulbs in both but they still dont work. The indicator and reverse lights work fine. Any ideas what it could be?
Dodgy connection most likely.
Common problem being a dodge connector, more common causes the lights to flicker.
Unplug the connector, clean the pins with WD40/tooth brush, check the earth connector (inside boot just below hole wires pass through)
Failing that check fuses.
  Abarth 595
a bit of WD40 worked a treat, cheers man.
