Whats wrong with your car right now??
The roof has started sinking where the holes were filled in.Headlights look w**k and need sanding, Crushed rear arch, Front bumper/ headlight cracked and wing scratched, Track rod end on drivers side is goosed, Something wrong with the ABS on passenger side. All in time for the MOT tomorrow lol
The fact the fucker has broken down on way to work is a bit annoying. Dash lit up like xmas tree...then no wipers....then no speedo...then almost like limp mode without light....so now hasnt got power to turn it over. Had new battery 2 days ago after same issues and worked fine for a day...now this. When she'a fine, she doesnt miss a beat. First problem in 2 years...but still unwanted/unwelcome!
I know the feeling don, mine broke down on saturday night and didnt find out what the problem was until wednesday! Turned out to be a 30 amp fuse had blown, i spend 3 days checking everything and it was something as small as that lol
Headlight washer pump and leaking exhaust. Both should be sorted tomorrow.
Other than that it appears ​to be fine.
My DCi is fine....
.... apart from the f*kin sunroof! The rattles! sometimes it does somtimes it doesn't. Just seems to be if its frozen then when its de-freezing I feel like punching my fist right through it.
Throttle body and blowing exhaust just past the cat, not done NEARLY as many changes and modifications as I would like, but other than that she is running happily :race:
The Clio:
Headlights want correcting.
My rear number plate needs putting back on properly.
My doorcard needs taking off, fiddling with and putting back on right.
Wheel refurb and swap fronts to rear etc..
The MX-5:
New wing mirrors.
Roof clip needs sorting.
New wipers.
Blowing exhaust, plus clunks at random intervals on speedhumps
Washers don't work
'Juddering' when braking slowly, possibly bleeding brakes may be required
Whine when starting up, could be water pump struggling
Clutch becoming heavier
Seeing other peoples issues make me feel a lot better about mine, they're normal :D! Plus almost 95k so not surprised the wear and tear is happening.
The car has been diagnosed with knackered alternator...so that is booked in for Monday. Just got one from renparts/cliospares as was and they sorted me out with one damn cheap...and £15 next working day delivery...so fair play to them. Its not much to go wrong really...so I will be back in love with the car by Tuesday hopefully. After all, its a relatively cheap hot hatch with a lot of toys sapping power...so its done well in 7 years. So I shouldnt really grumble. :)
Smashed front spoiler (cat)
smashed rear spoiler (cat)
passenger footwell lights dont work
ripped recaro seat
1. Needs cambelt dephaser water pump aux belt
2. Ktec engine mounts
3. Spark plugs
4. A bit more carbon fibre :)
1. Exhaust is rattling(scorpian) from what sounds like the middle of the car.
2. A squeaking noise from drivers side wheel / suspension ? ive booked it in to be checked out .
Washers blocked (somewhere in the pipework, need to get the washer bottle out to do it)
Squeaks like f**k when cold (Clutch?)
SERV and airbag light.
No heaters!! picking a new resistor unit tomorrow hopefully that solves it!
could do with some new brakes but at the minuite i dont use them so no point!
Dash vent rattles.Exhaust mount (I think) squeaking.Filthy.Need New wipers.Large-ish car park ding I have a pile ready to go and sort it but it's too bloody cold right now.
New subframe, hand brake cables, n/s front bearing, gearbox dog bone mount, anti roll bar bushes, new brake light unit and a service.That's my essential stuff, you dont wanna see my 'picky' to do list..!
Balljoint, exhaust leak and passenger door. 2 easy fixes 1 notso easy or cheap just hoping I can find one thats a good colour match so I don't have to get it painted.
Air con needs regasing, will be done before summer
cracked passenger wing mirror needs changing
annoying scratches that I've noticed while cleaning.
Key fob stopped working
driver door never locks with key fob (when fob was working)
Serv + airbag light have back on so need to check the connection underseat again.
Track rod ends being changed Monday.
Replace decat, due to M.O.T and its slightly blowing.
Wet and dry headlights and just a dam good hoovering and a full on wash..
Still wouldnt change it for nothing either...
Belts and dephaser, booked in for 23rd
Dogbone needs replacing
Washer pump needs replacing
Exhaust rattle needs fixing
Rear shocks need changing
Thats about it. Oh and it needs tax and insurance end of this month.
