Help Needed: Which Brake shoes for my 03 1.2?
J@Y
  Clio 182 and CBR 600
Hi guys,
My Mrs Clio anchored itself to the driveway over the weekend. The handbrake appeared to be stuck on the rear right wheel. I removed the front of the drum to find one of the linings had parted from the brake shoe and wedged itself to stop the wheel turning!
So I'm trying to order the correct part to replace it with but there are that many it's proving difficult!
It's a 2003/03 1.2 16v Dynamique WITH ABS.
Can anyone tell me what size the rear drums are on these? It's either 180mm or 203mm. I could measure it but the problem is the car is stuck at home, I'm at work and I really need to order today as she needs the car back on the road asap..
I've found these on ebay.
http://www.ebay.co.uk/itm/Mintex-Br...arts_Vehicles_CarParts_SM&hash=item2eba8099fb
http://www.ebay.co.uk/itm/220927644...id=m570.l2736&_nkw=220927644977&_fvi=1&_rdc=1
I'm assuming it has to be the larger one but can anyone confirm for me before ordering to avoid a further delay?
Thanks!
J@Y
Thanks. When you say should, I take it Renault mixed and matched and it's not always what should be on the car on paper/system?
Would you suggest measuring then to save ordering the incorrect parts?
  Lionel Richie
i'm 99% positive you'll have the larger ones, the smaller ones were fitted to the 8V engine, pm maynard to double check (GSF car parts manager dude)
