Id go itbs mate, reqlly change the way the car drives. Will make you smile. Pretty sure the gains are bigger too
got your email about cams. Can't really answer it in a straightforward way. Call me when you can, it'll be easier.
Sure you can!
"Both" lol.
Sure you can!
"Both" lol.
Get a K&N and a back box for the sound
Sure you can!
"Both" lol.
I'd base it on when your belts are due. If soon get cams, if not get bodies. You'll get more money back from the itb's if you ever wanted to sell .
if only. Belts done 10k ago so don't need replacing apparently.....where do I start :S
Correct, the belts were done 10k ago.
It's a strange mentality, if you want cams you want cams. It's that simple. What are you going to do, wait another 5 years till the belts are due again and then get the cams? Something to look forward to I guess lol...
I'd actually disagree with this
I have Jenveys + Omex, got 195bhp. I've seen quite a few cars on here now with cams hitting 190bhp.
Cams cost about half what the ITB's do
The ITB's do sound really nice and you get a sharp throttle - but it's not, in my opinion, worth the extra £1500+
I'd whack cams in and one of the new K-Tec induction kits, should get 190+ out of a 182 easily.
You'll keep driveability and some fuel economy too
Providing all you want is a peak figure to tell your mates down the pub your logic is bang on.
If you want a nice wide spread of torque though, I'd take standard cams and bodies every time personally.
If you want a significant increase though, just turbo it!
So the torque comes in much earlier with boddies?
It would be nice to see a graph of both.
What Jay is saying is they change the way the car drives, that is drivability. You gain a lot more of it through throttle bodies throughout the entire rev range. The sharp throttle response is mainly because you come from fly by wire to cable. Cams will take a little from low down and give it to you top end, which although gives you a nice peak figure of 190+, it will never drive as well as a throttle bodied clio with the same peak figures, or for that matter be as quick
I might have a set going cheap soon, just a quick pitch there![]()
I R No explain properWhat Jay is saying is they change the way the car drives, that is drivability. You gain a lot more of it through throttle bodies throughout the entire rev range. The sharp throttle response is mainly because you come from fly by wire to cable. Cams will take a little from low down and give it to you top end, which although gives you a nice peak figure of 190+, it will never drive as well as a throttle bodied clio with the same peak figures, or for that matter be as quick
don't itb's ruin fuel consumption?
North west I guess try Paul at RS tuning I’m sure he could sort you out with ITB’s and do a great job on them too
Price wise if paying someone else to do the work then I guess around 2.5k-3k
If you can DIY and then just get the mapping done elsewhere I guesstimate about 2k with new bits
LOL I fully understand that ITB's give you more torque lower down and the peak rpm over a more usable range
HOWEVER cams and a remap - you're looking £1200. ITB's and a remap - you're looking 3k minimum
I still don't think on a road car that wants a bit more oomph that it's worth spending £3k on a car that let's face it is only worth £3k.
Just my opinion. I guess I'm one of the rare minority that did it and just thought it was money better spent somewhere else
For 3k you could whack some cams in, remap it, fit some KW V2's and a diff.... just sayin'
