dci k9k solid buckets help!!
Dr HMS Derv Destroyer
Car  MK1DCi/vivaro/REN’11
hi all, does anyone know where i can get the solid buckets from?
, need to rebuild a cylinder head but the clearances on the solid buckets are all over the place compaired to the factory specs.
i know theres renault but id rather go else where if i can.
thanks in advance
raz
i bloody wish you can shim them up. unfortunatly not.
ah i see, the reconditioners around here wont do solid buckets, they will only do the shims :( ffs.
they're wrong, because shims aren't available. Sounds like they're not really trying, or interested. My place will do them, but they're special order obviously (in the right sizes)
how much does your supplier charge for all 8? obv you would need the sizes.
just thinking i have a back up plan to order them through you if its possible?
thats a dam sight cheaper than what i got quoted up here direct from renault , they quoted me £20 each , so thats £160 LOL
i'll give you a call when iv messured all the buckets again. ( messure twice an all that bla ) lol
if you dont mind ?
last one I did, I managed to swap them around until I only had to buy 2 new ones. Took a while (car sales place wouldn't pay for a set.....or anything for that matter)
i think i'm just going to buy all 8 new ones.
regardless if they can be swapped around. peace of mind that i dont ever have to touch them again in my ownership.
thanks for the specs aswell.
messured the clearance, but the buckets seem welded to the head, no magnet will pull them out . iv soaked them in petrol for half the day and still stuck ( like they are oversized )
what next? try cut them and pull out with a screw driver? ( pikey i know )
