Amp Wiring for CAMPUS SPORT '57 plate
Car  Twingo Dynamique
Ok, i've been searching as many threads as possible for how to get the power through my bulkhead. The grommet around the bonnet release is wierd, its kinda like, really long more like a rubber coating on the wire if that makes sense!? I've tried pushing a screw driver through it with the bonnet wire, but theres just no way its going through. where else can i route my power cable!! :(
you can just pull the grommit out and bypass it if need be fella, thats how i done mine.
And to make things easier when you run the cable to the boot make sure you have torx bits to hand and unbolt the bottom of the seat belts, that way you can pull the panels back and slip the cables under really easy.
Hope this helps
if you follow the release cable you can push the bottom side of the grommit out and feed it through, just make sure you pull the grommit up so you can pull the cable through freely and it doesnt catch
