Headlight adjuster light
Car  16v 1.6 Clio MK3 GT
Ok, so i managed to rip open the headlight adjuster only to find an orange plastic. i figured try removing it, surely would get a white light. didnt really work. Ideally i want this to be blue, so what bulb am i needing and also, do i need to get that orange plastic changed as well?
to top it off the bulb bust somehow as i was fiddling with it. lol....
looks to be a w5w bulb ( same as center dash desplay ) can you remove the bulb?
i can remove it, only if desoldered. not the same as a wedge bulb, its not a t5 nor is it an led, it has the classic bulb wire inside it....
