Lowering question...
Car  Clio 182
If I'm just getting springs (40mm spax for example) do I need to get shocks aswell or can I just use standard set up? Sorry for silly question but never done this before.
​Ta
You should be fine. Any lower than 40mm then you want to be uprating really.
thanks mate. Was never sure so thought I'd ask a friendly bunch lol what sort of shocks should I get if I was to go lower? And is that all I would need to upgrade?
ALSO, what sort of brake upgrades are there for a 182?
If you were going any lower, I would look into getting coilovers mate.
Depends what you want to do with your brakes. The common discs used on here are Brembo High Carbon's.
You can also get the Wilwood brake 4 pot's which are available from KTEC.
Or just stick some good pads in standards (like mintex 1144)
