Really bad misfire itbs just fitted
Just got my itb set up and running, but its got a very bad misfire, changed leads and coilpack, no difference, changed maf sensor, again no difference, its running a gen90 ecu with a basemap supplied by ktec.
Any other ideas?!
Thought the map sensor was the black one normally on the left hand side of the inlets and the air flow sensor was the small grey on in the right side of the inlets?
I'm sure RS tuning said the map sensor is now void with itbs but still need air flow and fit it into the backing plate?
RSTuning
  R35 GTR
Is it missing on just one cylinder or more?
Pull the injectors one at a time and see if it drops that cylinder or makes no difference.
