Polybush exhaust mount.
EuroCarParts also sell them but then need to be ordered so your quickest beat would be ebay
The ECP ones are sh*t, mine was f*cked after a week,
​i'm going to cut it out and zip tie a polybush in there.
ECP are a powerflex supplier.
I bought my powerflex bushes from ECP
I'm going to order a couple for my 182 exhaust, but find an alternative fixing to the good ol zip tie :D
Tap and die set, threaded countersunk screw that goes through the exhaust bracket, through the polybush mount then picks up a tapped hole other side of the exhaust mount. Worth a try, will give me something to do over a weekend.
Ah right, I thought you were talking about the standard ones, those are sh*t,
​How much are the polybushes?
I got mine for around £1.90 a bush but it was through staff discount at ECP.
ECP dont carry them in stock so if you are wanting the quick quick ebay or powerflex direct is your best bet.
As i say ECP are a full Powerflex distributor so if you have the powerflex part number you can get it slightly cheaper at ECP
I replaced mine with standard last year and 1 side has failed already :( but don't like the look of those cable ties lol
Im actually going to tiger seal round the edge of the mounts also aswell as cable tie them.
​There has been users on here using cable ties with no problems
Do they come with the circular hole cut out in the middle or do you have to do this yourself??
You need to drill it yourself, depending on how tight you want your exhaust sitting against the rear bumper or how low you want it hanging boils down to your hole drilling skills
​Wtf is tiger seal lol is it like grip fill??
Tiger Seal is like a silicone filler.
You can see from the picture below that someone has went alittle OTT with the tiger seal.
Im just going to do round the edges of mine and im not filling the whole lot up.
I also used it on my Vectra for the top mount.
