Misfiring or just because I'm in the wrong gear?
Car  Suzuki Ignis Sport
I'm not sure if my car is misfiring or just juddering because I've took the corner in the wrong gear. Is there any foolproof way to test if a car is misfiring under load?
Probably misfiring, my 1.2 started with age and eventually stopped firing on one cylinder all together. A new coil pack cost me about £50/60 from Partco.
Just been done, brand new plugs around a week ago. Only thing I can think off is those rubber caps in the end of the HT leads, cut them out as they got stuck on top of my spark plugs and couldn't get them out. Could be the reason its misfiring I suppose, but unlikely.
put it in 5th at about 30mph 2000rpm and then accelerate will be under load and miss if its going too.
if you have the recite for the coil pack take it back as it will have a 12 month warranty.
This is good, but the misfire could appear at high rpm or right down low at idle. I find that going as slow as possible in 2nd, then doing a full pull right through the rev range is pretty good for detecting misfires, as you won't be accelerating quickly enough that a 'bad spot' at, say 2500-2700rpm would be missed, yet you won't take so long to accelerate that you'll run out of room everywhere you try to do it (obviously a safe place is recommended), or be going at super silly speeds by the time you've finished.
Definitely misfiring. I try to use higher gears as much as possible, so looks like coil pack.. a garage did it I used to got to. How cheap can I get them? Brand new ofc!
Tried the 5th gear trick, happens the most in 2nd when I put my foot dowb.
I bought a coil pack from Eurocarparts for £24, using a discount code (there's loads of places which list ECP codes, have a google!)
Used one similar to that, was PARTS25 I believe. Got a coilpack for £33. Going to pick it up today, mines the one with 4 torx bolts. One question, how do I fit it? As in, which lead goes into which plug? Is there a diagram? Cheers guys!
All done, got a coilpack for £33 with PARTS25 from ECP. Fitted in car park, running sweet now! Cheers guys for all your help :-)
