¼ Mile At Pod - Saturday October 19th
It's those tyres of Chris's, loads of grip. If you listen closely it actually bogs down, I had to dip the clutch to bring the revs back which brought it back to life.
With sticky rubber the car wants a 3.5k+ launch instead of 2.5k-3k which I was doing...Anyone know of a transmission rebuild place?!?!
was going to say that bogged a bit. Agency seem to be rated highly on here
Why you want a rebuild for?
The box is fine. I was just implying that if I ran slicks next year and was launching at 3.5k it probably wouldn't last long!
Martin wants another user name change. MartintcR ;)
Good idea Don;) no only joking i wouldn't do that. :)
Id be wary launching at 2.5k especialy with the record of the circlip in the jc5's.
If you get it rebuilt see if the diff can be bolted like the 182! Nothing worse than pulling off an bang it goes! Been there a few times:(
Diff can be bolted with that adapter plate, freind of mine with a cup did his.
Works fine, even if I think the m5 bolts are to small. Saying that it's 8 bolts so should be fine
Dunno, he tired 4 bolts first and it ripped the heads off it, it's got 8 in now and hasn't popped even with the amount of stick he gives it
