182FF
				I've been having lambda lights on and off (when I reset them..) for months. Swapped front to back and it fixed it for a while. But the lights are back complaining P0130 (Pre cat lambda). It's been running fine and I can see the voltage switching using an OBD adapter.
So I think it needs a new lambda sensor and I'm not paying £60 for one with a Renault plug on it when I can just solder the old plug onto a £15 genuine "universal" Bosch sensor.
So just to check, the sensor is a "Zirconia" right? The old fashioned standard.
Also, if anyone has one lying around new, could you measure the heater resistance for me? The two white wires.
