16mm hub centric spacers just to show the difference
  Q7, traffic van
Picked up a new unused set on eBay for £20, so wanted to trial 16mm front and rear before deciding if I wanted more. Took a couple of pics to show the difference from standard (205/45/16) on standard 16’s.
first pics on front, second on rear. Looked so much more aggressive and with fast road use there wasn’t any noticeable difference.
second pic swapped to the rears.
I’m going fairly low as I’ve just purchased a set of gaz adjustables (rear spring on damper so I’m think adding a set of 5mm axle spacers too as I know the wheels will tuck a little more.
