Chrisgti6
								Too many
				Not on a Clio, this is on my MR2 Roadster.
Sent it for an MOT yesterday but it failed on emissions. HC and Lambda were a pass but CO was over. Picture of the results below. It did previously have an engine that was burning a whole lot of oil, so there is potential for there to be some residual oil in the cat & exhaust system - would this cause high CO or am I best off looking elsewhere? I have a spare cat and exhaust I can swap over and some spare lambda sensors if needed, although I do have a decent diagnostic tool so might check out the lambda readings before swapping them out.
Obviously I only get one shot at a retest so is there anything I can look at in my diag tool to indicate if I've reduced the CO? Post cat lambda readings maybe?
