Emissions MOT fail
Chrisgti6
  Too many
Not on a Clio, this is on my MR2 Roadster.
Sent it for an MOT yesterday but it failed on emissions. HC and Lambda were a pass but CO was over. Picture of the results below. It did previously have an engine that was burning a whole lot of oil, so there is potential for there to be some residual oil in the cat & exhaust system - would this cause high CO or am I best off looking elsewhere? I have a spare cat and exhaust I can swap over and some spare lambda sensors if needed, although I do have a decent diagnostic tool so might check out the lambda readings before swapping them out.
Obviously I only get one shot at a retest so is there anything I can look at in my diag tool to indicate if I've reduced the CO? Post cat lambda readings maybe?
Chrisgti6
  Too many
High CO suggests a rich fuel mixture, but then the HC (unburnt fuel) is way low 🧐
See what your lambda readings are.
Yes the lambda and HC results being where they are suggest a good fuel mixture, but high CO says otherwise which is slightly confusing!
What should I be looking for on the lambda readings? It has 2 precat and one post - would I need to be looking at all 3? Looking at voltage fluctuation I assume? I know my tool can record the results so i'll have to risk taking it out without MOT and get some readings done
Mr Trailer Man
Yeah the precat should be fluctuating steady wave up and down.
Post cat should be a steady line/voltage.
Chrisgti6
  Too many
When was the last oil change? recently had one where just an oil change was enought to bring the CO down on the emissions
About 5 miles ago :). It had all filters, plugs, oil, belts etc when I put the engine in the car. It runs spot on so I can only assume the cat needs a proper clean out or swapping.
R3k1355
I thought the MOT manual starts the emission testing procedure by saying something like: "Find an exact match in the MOT database"
Steve
  LMC10, Puma E
Didn’t know where to put this, but I know these discussions come up a lot.
There appears to be significant change on the horizon for the MOT, with not only increased costs for garages but also tighter regulations that could affect many motorists in ways that aren't currently a concern
Currently, an illuminated engine management light is a reason for failure, as it indicates a potential issue with the vehicles emissions system.
However, it seems this could be extended further to include direct interrogation of the ECU for fault codes that may not necessarily trigger a warning light.
There also appear to be plans to introduce readiness checks, which would prevent drivers from clearing fault codes shortly before an MOT test in an attempt to avoid detection.
So does this mean all those with CAT delete DPF & EGR code outs would be failures!
R3k1355
Haven't they talked about this previously, but the cost was never worth it?
How do they think these readiness checks will prevent someone clearing DTCs before they arrive at the testing station?
McGherkin
McPension
On most OE ECUs, clearing DTCs resets the emissions data and the car has to drive multiple cycles in order to satisfy itself that it passes the readiness checks.
If you clear DTCs before driving to the testing station the car will say it’s not ready when you plug it in.
