Renault Grand Scenic 300mm
MarcB
  Vw Golf
My Clio has the 300mm Brembo conversion and im looking to change my discs and this is the size the Renault Grand Scenic
  • Diameter [mm]: 300
  • Height [mm]: 44
  • Brake Disc Thickness [mm]: 24
  • Centering Diameter [mm]: 61
  • Number of Holes: 4
  • Minimum thickness [mm]: 21,8
  • Tightening Torque [Nm]: 110
I have the OE Part number & the brembo part number but im looking for a drilled or grooved disc rather than standard.
The only things I have managed to find are the 300mm J Hook discs from Godspeed.
What have other people fitted who are running the 300mm discs ?
ripp
  182 FFAT
Swapping to the godspeed or pm 300mm discs is s good idea and here's why: the brembo calipers were constructed for 28mm thick discs like on the 197/meg2 rs.
That meas the pistons won't be exiting the caliper as much when the pads wear out and the most important thing is the 28mm thick units have way better cooling. I'm thinking of getting them also (i run the same setup-brembos and 300mm scenic discs) but I don't know how tall the godspeed ones are versus the 44mm tall scenic ones. If their centerline differ then I'll have to modify my existing brackets.
So if anyone knows their dimensions please share 🙂
ripp
  182 FFAT
I found out- the floating 300mm godspeed discs are 0,6mm inward versus the std discs, so basically nothing. So that means they are plug and play if you have brackets made for the 300mm scenic discs, hope someone finds this useful :)
