I can turn it off, but can’t code it out. So it will come back on.
Is it for an MOT and is it because you’ve swapped the wheel?
I have renolink which I believe may be able to do this, I’d need to check though.
Never seen so many offers of help.
I can drive over and do it for a sniff of your seat?
You love sitting in a moist seat stop playingI (and Daz) live 20 mins away from her you melt. So it shouldn’t be surprising we’re offering help. 😂
Prob miles away from me at a guess or could do it. Can be done with clip, renolink etc
Stage x ?
I believe she's fitted Recaro Trendlines, so it will be seat airbags.
I could do it if you were ever in the North West @Bubbles
It can, but you may need Google Translate open as a lot of the menus/settings are in French 😅
I’ve managed to turn the warning light off after removing the resistors for my steering wheel now. Took a bit of trial and error but after having everything saying it was broken I’ve worked it out 😅
Exactly that, you can only turn it off if it’s not there otherwise it’ll still throw an error code.Easier with the resistors taken out and letting it tell you what's missing. Guessing that's what you did?
