RSTuner - remap and airbag coding
Car  Clio 182 Cup
Evening all,
New to cliosport to apologies if this is already a pinned topics somewhere.
Looking for someone to map my cararound the Bedford area. I’ve heard it can be done on RS tuner? Also would like airbags coded out too.
Hopefully someone can help.
Airbags won't be an issue, you just need someone with the module to do it for you, I'd happily help if you're ever up in the Nottinghamshire/Lincolnshire area.
Mapping with the RSTuner essentially locks the RSTuner to the car, which can only be unlocked by buying a key from Henk, so you would need to buy at least one licence, 70eur from memory when I did mine, to unlock and potentially a 2nd to unlock it back to the owners car. Not an issue if it's a brand new one which locks to the first car it's used with. Might be better off buying either 2nd hand one + an unlock code, or a brand new one from fastchip. Hope that makes sense.
Thanks appreciate this - I actually have family that live just below Lincoln so I 100% will take you up on that offer.
In regards to RSTuner - I’ll take a look and see if I can buy a unit! Appreciate the reply.
Might be worth checking if it's been mapped before, quite alot have. Been a few people that have gone and bought themselves RSTuner, plugged it in and seen the map already on the ECU.
Is there any easy way to check? I don’t think it’s mapped from what I’ve heard from previous owner
The usual way to tell if it's running the stock map is if there's a noticeable 'kick' to the engine at 5000rpm. It's as if suddenly the engine comes alive and pulls harder.
It's nothing to do with variable cam timing, it's all down to how the stock map was written.
Yeah so mine has that kick, and only revs to 7200rpm so I think it is a stock map
Yeah I’m not far! Although I’ve since realised that you need an airbag module to code it out, u don’t have any of it fitted - abit of tape over the light I think is needed!
