Help with srs
Car  Clio 182
Hi can someone help
My clio 182 cup has the srs light on and it's showing codes relating to short cir uit in driver's airbag and both rear pre tensioner open circuit
I checked the rear belts and theres no pre tensioner on them so I'm assuming that the ecu has wrong calibration in it
I'm looking for someine who has the correct software to be able to sort this for me
I'm the yorkshire area
I can reconfig the airbag ecu, redcar.
If you have oem steering wheel on and its connected up, might be other issues i.e. squib.
Hi I checked the continuity through the squib and that was ok
I have a spare airbag
I'm going to connect that up and see if it clears the short circuit code
If it does I'll replace airbag
So your saying you can reconfigure ecu to remove the 2 rear pretensioners
Yes reprogrammed loads of airbag ecu's on clio2, can sort it with clip.
Excellant
Got a code in abs too for steering wheel able circuit
Need to check the wiring to this first too as think it might be faulty module
Guess asr light is also on. Squib might need recalibrating.
