DA Polisher recommendations
Matthew_
Looking to get a DA polisher to use on the Clio nothing crazy expensive or fancy really just to tidy up the car. But there seems so many options on the market not sure what's best.
Any suggestions would be great thanks
Having looked online i set a budget of around £100-£150 but not sure if that's okay for a decent one that will last?
Cheers for the tag :).
What polishers have you seen? Like you say there are hundreds.....
Budget 100/150 is easily enough. But factor in you need pads, polishes etc.
I’m always tempted by one of his for sale ads, but I just know I’ll end up burning through my paint work 😂
Unless you put a 50grit sanding pad on or forget to put any polish on the pad, you'd struggle to burn anything. You're more likely to get bored waiting for smoke than just smashing thru the clear coat.
Especially on a BMW. Paint is like granite usually 🤣
Wrong I'm afraid. You sit there long enough with an aggressive pad and compound and it will burn, trust me lol.
I tried to remove a deep scratch on a sales car, whacked out my 3" (polisher) with red flex pad, roar compound ceramic.
It was either scratch gets better/removed, or paint. When my pad turned a hint of blue I know it was time to admit defeat, well not defeat as such as the scratch was 90% better/acceptable but i definitely burnt through, only a small patch (not noticeable (
Also did it on a grey MK4 Clio years ago, way more noticeable then lol
Worth a watch
I will be looking to put this up for sale if interested, condition is excellent.
Will include a few pads, polishes to get someone going.
Look at this product that I found on google.com https://share.google/gINvP3HrIEvjc5kPx
The autofinese one was the one I'd heard of but didn't know if it was any good.
By the sounds of it your the man so I'll keep an eye out for your for sales posts on the forums.
DAS6 Pro was always good back in the day.
Thanks I'll take a look at them
Thanks for all the advice guys 👍
