Oil Sandwich plate order
Struggler
Car  Ph1 track 172
What order do people run their sandwich plates (assuming they have two)? Most of the ones I've seen are as below, sensor take off first followed by oil cooler:
I've been thinking that this doesn't make any sense. Since both plates affect the outer channel of the oil path, and the oil filter flows in the outer section and out the middle.
What this means to me is that the sensors will be taking their reading upstream of the oil cooler, but surely the actual pressure/temperature of the oil hitting the engine is more important and than the pre cooler data.
Wondered what everyone else running double sandwich plates is doing and if I'm missing something here.
I would run single plate that covers all instead of double stack, less to go wrong.
You could get a boss welded in sump for oil temp, and tee into the oil light sensor for pressure.
You guys are an exercise in patience! 😂
Would use a double length fastener so shouldn't be more to loosen, you could argue there is more seal area to fail but still, not a question of the merits of a single plate over a double stack, just in the logic of sensor/cooler order!
I'd never double stack sandwich plates, you're asking for trouble.
As has already been said, either buy a plate with a port for sensors, or fit them elsewhere - tap into the pressure switch for pressure and either the sump or oil cooler line pre-cooler for temp.
I've got a mocal billet sandwich plate with a (as yet unused) sensor port on mine
You want to know the temp of the oil coming out of the engine, it's closer to the temperature that's actually inside the engine. Same goes for pressure.
If you measure those after it's been around the cooler, I'd imagine there'd be some pressure drop and you'll only know the temperature of the oil you're sending into the engine. (which if it's too high at that point, is probably too late)
