My glorious Clio
Car  Clio k4m 2004
Hi guys! First post here. This is my little Clio Ph2 1.6L—my very first car. I’ve been enjoying it for a year now; it has always driven flawlessly and really likes being thrown around corners.
It has received a good amount of maintenance and its first few mods:
Oil, all filters, spark plugs, belts, etc.
Lower ball joints
Tie rod ends
Rear shocks
Front brake rotors + pads
Mods:
Renault Solonia 16-inch 6.5J wheels (originally from a Clio 3)
RS grille
Bluetooth radio
Questionable lights
Next up, I want to improve the handling and sound.
I'm planning to switch to 195/45/16 summer tires instead of the current 195/50/16s, as those are a bit too tall. After that, I’ll probably get some lowering springs with aftermarket shocks (I'm open to advice on handling improvements!).
I'd also like some more induction noise, maybe with a different air intake? (Again, open to advice/suggestions!)
So, this was the introduction of my Clio. I hope to meet some like-minded people here and learn new things about these awesome cars.
Kind regards!
Just get the cams , throttle body , injectors and upper and lower intake from Twingo Rs , i can see that you got the 1.6 16v version , on that engine you can put the megane 2 head that has the dephaser and all those bits from twingo rs and it work like a charm . Need more info just ask .
Welcome aboard!
I'd personally say that induction noise was perhaps overrated, until I made the swap from the OEM kit to the KTEC 2RS induction kit earlier in the year.
I don't know if it was that on its or a sum of the several changes previously made - cams, map, exhaust, etc - that made it sound completely different. Under slight to medium load, it has a definite burble, almost Subaru-esque. But get it on a decent B-road and up to 5k rpm and beyond and it sounds superb - in my opinion, of course!
Would be interesting to see if you can achieve similar with the 1.6 16v unit.
