Which Battery?
lee M4RSH
Just wondering what battery you guys are using on your 1*2?
Mine is just for track so doesn’t get used all of the time.
I’m having to charge the battery every time I want to use it for track days which isn’t a problem but not ideal at the same time if I need to move it randomly.
Battery is still in the engine bay so standard battery size will be fine.
I've got a Bosch S5 in mine, although it did start leaking acid so not sure I would recommend it if you let it go flat every now and then 😂
I run a PowerLite PS-09 Lithium Ion battery, with a Durite 2-021-00 disconnect terminal, easiest weight saving I did on the car, 10kg iirc. Bought it back in 2020 and it’s been fine, I take it off over the winter and leave it on a trickle charger in the house as I have no power in the garage, otherwise I leave it on the car but disconnected over the summer when in use. Not sure they make this exact model anymore but worth looking into an alternative if you fancy some easy weight saving, you will just need to make up some sort of clamp to hold it in the bay or such like.
Is a Bosch still the go to battery for a 172 etc? I currently have an S4 001 which is old (2018!) it's got on it 44AH 12v, 440A.
I went on ebay and they still have S4 001, but they also have S4 002 and S4 003 which one of those is the one want?
Cheers, do I buy the same as what's on it? an S4 001 ?
Yeah s4 will be fine, check its the right spec and send it.
My theory is buy the cheapest to spec bosch as it will prob need replacing in 3-5 years regardless
I went with a Bosch S4 002, which is 15mm taller than the S4 001, but 52ah instead of 44ah. I don't use it that much so I figured it would be better.
