1.2 16v Misfire (53 Plate)
1st post guys.... Hi!!
Posting on behalf of my friend. She has a 53 plate 1.2 16v clio.
It's developed a bad misfire, idles really bad and has no power at all. Emissions light is on too.
I've had a quick check over the car, no oil in water or water in oil. The coil (one piece unit with integral leads) on all four leads has a reall really weak spark (dull orange, i'm assuming it should be blue/purple/white), spark plugs seem fine tho.
I've done some research and the coil seems to be a common fault.
Is there anything else I should test (if yes, what and how?)
Any help would be appreciated and you'll get me some brownie points with her ;)
Thanks.
Rich.
  LY 220 Trophy+IB PH1
Emissions light will be the petrol going through to the cat, i'm not familiar with the exact engine layout but try this, start the engine up and remove the coil leads one at a time, you should notice when a working one is removed the engine will struggle (or stall) and the other 3 will try pick up the slack, when you remove the buggered one the engine will show little difference.
If its just one big block you might have to replace the unit :p
Also does the engine vibrate alot ?
  ITB'd MK1
See this: http://www.cliosport.net/forum/showthread.php?t=481563
unless you've got the newer style engine...
lol, that thread is funny. £1300 for a loom hahahaha. they're about £150 new from renault, and a couple of hours labour, plus probably a bit of diagnostics time, as there's a lot of fault codes get thrown up and you can't tell what the loom is causing until it's replaced. I've seen 13 fault codes, and 8 fixed by a new loom
The engine vibrates loads yeah! You can defiantly smell petrol too :(
Yep, i've heard of that, I will have a look tomorrow in the daylight.
Thanks very much.
  Clio 1.2 16v
Re: 1.2 16v Misfire (53 Plate) C
Thanks.
Rich.
I have a 2002 plate clio 1.2 16 valve which developed misfires. Looked at and replaced wiring loom, coil packs, lamba sensors all of which showed up on the diagnostics. Imagine how frustrated I was to find out that cleaning the Throttle body thoroughly solved all these issues in one go. A dirty throttle body causes all the diagnostic readings already listed and is an hours work for any competant mechanic or DIY person. A complete step by step process can be googled saving you £'s and £'s. Hope this helps all clio owners with a good cheap starting point for a misfiring engine. There is always the possibility that the problem could be caused by something that needs more specialist help but the initial cost is worth it. Worked eventually for me after I had looked at everything flagged by the diagnostics!!!!!
  Clio 1.2 16v
Thanks.
Rich.
I
  Clio 1.2 16v
How to clean a Throttle body on a Clio 1.2 16v
This model has the Throttle body inside the inlet manifold.
This should fix issues you have with your Clio idling erratically, misfiring, cutting out when pulling away and juddering at low revs, it should also stop the coil light from staying on in the dashboard and giving false readings on the computer when attached for diagnostics.
Tools needed:-
1. 10mm socket with extension
2. 8mm ring spanner
(to disconnect the earth from the battery)
3. Star socket to remove the throttle body from the manifold.
First you must disconnect the battery then pull out all the plug caps and place to one side and disconnect all of the wires on the engine loom that are attached to:-
1. The Air Pressure sensor
2. The coils
3. Unclip and lift up the large plug at the back of the engine (the black troublesome box can be removed, see at the end of this tutorial)
4. Remove the oil breather pipe and the other pipe to the left of the air filter
5. Remove the petrol pipe (bottom left of photo) this will be really stiff, just keep the green sides of the plug pressed firmly in and ease off
Note: Do NOT try to pull at the loom on the right hand side as this goes inside the manifold
Now unscrew the four bolts on the top and also the 10 bolts on the front, you will eventually find them as some are real hard to see, I must point out that you will need a THIN 10mm socket and at least a 6 inch extension to reach these bolts.
Once everything is unscrewed and disconnected, lift the manifold up a little then pull forwards slightly to free the manifold from the head. Now tilt the manifold forwards and again lift up and rotate the whole lot towards you, you will see the throttle body with a loom plug and the oxygen sensor plug. Disconnect the two plugs and remove the wiring loom from the manifold, this is a little tricky as you need to pull the loom out and over a plastic lug. You do not need to disconnect any of the fuel injectors. Now with the manifold upside down you will see the four retaining star screws holding the throttle body in place.
Here are some photos of one that was supposed to have been cleaned by a local mechanic, he was obviously a cowboy. Also below in the photo is the oxygen sensor that is completely full of oil, this will give incorrect readings and cause your Clio to rev up and then drop to almost stalling speed, it will eventually either cut out or slowly settle down. Other symptoms of this will be stalling when pulling away and misfiring at low revs.
The socket for the oxygen sensor which was also filled with oil, you can unclip this sensor and spray it with carb cleaner to clean all the crud off.
What the throttle body should look like after you have cleaned it up.
Soaking up a ton of oil inside the manifold, make sure you clean every drop you see in there, also there is a very small breather that you must check and clean out shown in the right hand photo. Make sure you do not push the crud back into the hole.
Another important job to do before putting everything back is to clean any corrosion off the cylinder head, if you do not then the chances are that the manifold will not sit snug and you will get air leaks. Its always good to replace the four gasket rubbers if they are worn, but to be honest, if you clean the head up like I have, you will not need to replace them. I have never had a problem using the old gaskets again.
OK now your all ready to put everything back in reverse order, take your time and don't rush or force anything into place, once you have everything back and plugged in and bolted up, start her up and be amazed, it may run jumpy for the first few seconds because the petrol was emptied from the injector tube when you turned the manifold upside down, but after that's filled again you shouldn't have any problems..
I took the car back to the woman I fixed it for and she took it for a test drive, when she come back she was crying with joy because she had been having so many problems with her car since the day she bought it, she was just so happy that it was fixed at last. She had been charged an arm and a leg by Renault and cowboy mechanic and neither of them had fixed the problem for her, they just come up with excuses that this sensor or that sensor was at fault.
I hope this tutorial has helped you fix your car and have saved you £100's of pounds from a Renault dealer. If so, I am glad I have helped.
The black tamper proof box.
The Black Tamper proof box that eats its way through wiring looms!!! To remove the casing that is rattling around, remove the loom plug and lift it away from the plug housing, then on the far side of the metal housing bend it away from you about 30 degrees, It can be done with a little force. Then once you have done that, pull it towards the engine and rotate it away from you, this will need some strength but it will come free and you can then put it where it belongs, in the bin.
  Clio 1.2 16v
