Dan@M.A.D Awesome. How much for a set?We can supply the bolts if needed..
When I originally looked in to this for my 10mm spacers, it was recommended that new bolts were not needed, originals suffice, anything over 10mm then you do definitely need new ones.This is probably a long shot but does anyone know the best bolt size for 10mm behind-the-disc rear shims?
£7 delivered.
See your point, but the Renault nuts have built in washers that are curved and then compress flat when tightened.Youd be better off removing the washer to get more threads into the nylon.
