15 inch qheels revcounter
  Z4x2 & buying a 182
I'm sure this must have come up before but can't find it.
Just fitted 15inch OZ wheels, very very happy with them, car feels great.
I noticed the revs now go way beyond recline...guessing its due to going from 16 to 15?
Will check the speed vs GPS to see if that has been affected too.
I assume this is what's happening right? If not I'm gonna have to reign it I!
Coops Mk1
  Lots of Scrap...
Usually with tyre profile change too the actual difference in rolling radius is negligible
Crybert
  Cup 172
There’s a difference between going into the redline and hitting the limiter..
as above the difference is tiny in reality
NorthloopCup
There’s a few calculators online that will give you a definitive answer.
I used one when I geared my cup for the Nordschliefe. Swapped out the 5th gear for a meg 5th and went up from 15’s to 16’s. End result was 153/154 (on the limiter) iirc on the straight running down to Schwedenkreuz.
I’ll see if I can find the one I used.
I would have thought speed would have been out not revs?
As above I can see why vehicle speed might be out, but can't understand why the max rpm would be higher.
I guess it's a 182 going from16 to 15", so engine speed measured by the 'thingy on top of the flywheel', and vehicle speed comes from the ABS sensors?
I do understand you would get to max rpm quicker with a smaller rolling diameter, but will that actually increase the max RPM?
