20VT Clio & 9-5 HOT
my car was occasionally having a mardy and cutting out when the revs dropped and have a low idle. if i let it idle for a bit it would sort itself out then it would be fine for weeks.
Then it did it, but never sorted itself out. did it all the time! so i:
- cleaned iscv
- changed speedo cable/road speed sensor
- and gave it all a good clean with carb cleaner!
was a bit better but still did it!
Just now iv replaced:
- iscv
- potentiometer
- throttle body
it idled quite high for a bit, then i went for a drive and it was fine, but then it stalled again about 3 times out of 5!
once fully warm it was spot on, didnt stall at all, but idled slightly too high for a few seconds! i pulled up and let it idle and the revs slowly dropped to about 700-800 as before!
im off to buy a new lambda sensor to try but anything else? coolant sensor?
Also since its been playing up it refuses to pop and bang as it did before! underfuelling maybe?
