17 inch on a valver
Ive just shod my valver with a set of 17" wheels wrapped in 205/40/17 and it looks awesome. Just wanted to check, is it normal for it to rub a little bit on full lock? (its not lowered)
I would have thought its a possibility, seeing as theyre a bit bigger than standard - ask GlennX, as his is on 17s and is also on the floor, so should have a good idea. If its only rubbing on full lock then I wouldnt worry too much as youll only be doing slow-speed manouvering anyway!
I have 17s on my phase 2 valver with the same spec rubber, no rubbing at all even at full lock and it also dont rub with my 15 stone cousin sittin in it either;) its not lowered and suspension is standerd..
I bought my wheels off Adam_16V and hes car was lowered and he didnt hav any probs with rubbing....
I dont think it should rubb, you sure you got any spacers fitted?
  clio williams, Ph1 172
Mine rub on the front bumper. but mines a bit low and has 215 tyres on. only catches on drivers side really. back sometimes catches on hard bumps etc.
