172 bumper removal guide?
Car  2001 172
Can I find one on here??? can I sod !!!!
Anychance someone could stick a link up for me ??
thanks in advance
Could also do with a guide on how to remove the rear quarters to get at the rear speakers in a 172, as I cannot find one of them either?
many thanks again
iirc to get to the rear speakers, the "grill" sort of thing that's over the top of them just unclips, i'm sure when I did mine I just pulled it off, but I took the rear bench out first as it goes down the side of it, so it's just easier to take it out.
basically all I want to do is change the speakers. is this possibly by pulling the grills of? it wont break them will it?
thanks again
Rear speaker is accessable from the rear grille part, it covers the cupholder and stuff and is pretty sturdy.
so it shouldnt break by yanking them? and thats defo how u access them ? just a bit worried thats all
no won't break them, once you get inside it the speaker just unscrews with a torque screwdriver, the standard speakers have funny ends on them though, so you will either need to chop the wires or get an adapter for them.
If your planning on cutting them, here's a list of the speaker wire colours
Front LH Speaker
Beige: Positive
Pink: Negative
Front RH Speaker
Beige: Positive
Pink: Negative
Rear LH Speaker
Beige: Positive
Pink: Negative
Rear RH Speaker
Brown: Positive
Green: Negative
I got the adaptors for my fronts, and then had to crimp new ends on the rear as I couldn't get hold of the adaptor for the rears.
