172 Cup clunk clonk
ex-Chinese Dave
Car  172 Cup
Noticed this the other day....from the drivers front area, if I come off the gas quickly at low speed there is a clunk/clonk noise, but it doesn't do it all the time. All the suspension bits are newish, wheels are on correctly, no issues with braking etc and it only does it as described. I've driven left and right at full lock and there is not a peep. I was thinking it' could be a driveshaft issue but that would happen all the time, right? The only other thing is the top mounts, which are also newish and OEM parts, because we all know that top mounts can be a b*stard bag of sh1te from time to time. And this is not my other clonk that i've posted about.
Any ideas as to what it could be?
Not this kind of clunk clonk is it?
Mine was doing something very similar, check your top engine mount
Does it only do it when dry? My nearside clonked at low speed and when using large lock. I stuck on a small amount of silicon grease and it went away ...
It's only done it the last few days so mostly in the damp. My dogbone is also newish and i'm certain it's coming from the front right, not underneath.
I have relatively newish Vibra technics mounts and the top nut had worked itself loose on the top engine mount
Right, I just checked the top engine mount using a standard extension coupled with a half extension from my socket set. Just with that I was able to put about a quarter of a turn on all five of the bolts
/nut. I’ve tightened them as much as I can without swinging on the bar and so let’s see if they were the cause of the knocking. I’m guessing it wouldn’t take much to make a noise if those bolts/nut were slightly loose. I’ll keep an eye on them over the next few months and get them torqued up correctly when it goes for its next service.
Torque specs for those bolts along with a load more are here just so you don’t over do them.
My Cup had a clunk to it a few years back after I rebuilt it. I used the wrong size bolt from ball joint into the arm, which mean't there was play.
Not sure if you've replaced them recently. Even if OEM one might be loose?
I’ve just jacked the car up and had a good look underneath and there is nothing obvious that looks like it’s come loose. For all of yesterday the car did not make this noise. It was originally doing it at slow speed in second gear when I dubbed the throttle on and off. I tried to replicate that yesterday and there was no noise. Again, when it goes for its service, I’ll ask for all of the suspension components to be torqued up again to the correct amount.
This little issue is not related to my other clunking noise in the other thread. If you was in the car, you would hear clearly that they are different different sounds from different locations. I think I’m going to start my own DVD box set of strange noises from the front of the car that come and go whenever it feels like it. 🙄
Check torque on ball-joint to wishbone bolts and also subframe to chassis bolts. At different times I’ve had clunking noises from both.
