172 cup info?
Car  Silver 172
just curious, what do they 172 cups have that the normal 172s dont have? and what do they 172s have that the 172 cups dont have?
Do a search mate loads of info on here. The Cup has these differences over a standard 172
Profile 3mm lower
Front bumper with additional lower section
Enlarged rear spoiler above hatch
Greater downforce
Revised suspension
Higher front spring rates
Front track 20mm wider
New wheel rim offset
Overall weight reduced by 89kg
Spare wheel removed (replaced by 2 anti-puncture inflators)
Air conditioning removed
Side airbags removed
Xenon headlamps removed
Rear headrests removed
Central rear seat belt removed
Auto-lights removed
Headlight washers removed
Heat reflecting windscreen removed
Thinner glass used throughout
Engine cover removed
Leather/alcantera seats replaced with cloth
Sound deadening adapted
Braking system redesigned without ABS
Front castor angle increased by 3°
Rear track 10mm wider
16"x7" Speedline 'Turini' alloy wheels
Profile 3mm lower
Greater downforce
Revised suspension
Auto-lights removed
Best colour for a 1*2 by a mile
:o
Lol. All that was copied and pasted out of the Brochure........... Suppose what it means is bigger spoiler, and lower bumper splitter. I'm sure it will help clear up airflow *slightly*
Thinner glass is also true. The windscreen doesnt have the UV anti glare layer the 172's have.
Thiner glass is also true. The windscreen doesnt have the UV anti glare layer the 172's have.
00000.1mm thinner then lol
