172 differential preload
scruffydubber
Car  RS CUP
Hi all,
I'm fitting a LSD. Undecided between the Mfactory or Quaife at the moment.
Can anyone advise me on what the diff preload setting should be?
Many thanks.
Preload for bearings? Or preload for ramp angles? If it's the former, you set it up using shims. If it's the latter, you can't do it on those types of diff. They're a plate diff only job.
