172 jerking when pulling off in 1st gear and slight juder when slowing down
  Clio 200 full fat
guys when i pull of in 1st at slow speeds in my 172 the car jerks and then goes as normal also every now and then it wont go in to 1st or wont let me go in to reverse i have had the coil pack just done btw i have also had a new gearbox and clutch and when im slowing down the car jerks then as well but not through the brake pedal the brakes are also new can someone please help me with this
many thanks
terry
Mr R.
  A special one.
Let's get the story straight, you had a "used" gearbox fitted.
Id say it was the diff and id say that the box needs to come out and be rebuilt.
-J-
  RS2'ed 172 Cup
ive literally just had a gearbox rebuilt last week tho
Take it back to whoever rebuilt it?
You really either have been very unlucky with this car or have a total lack of mechanical sympathy and have managed to destroy another gearbox.
-J-
  RS2'ed 172 Cup
So who rebuilt this one? Did they not offer warranty? What did they say when you called them?
  Clio 200 full fat
local garage in Chelmsford he did offer a warranty on it it only really started judering last night so i have not called yet did look on here and a few people who seem to have the same problem have said mounts i just wanted to get a second opinion before i called the garage
  Clio 200 full fat
small update which may help just drove my car when you don't use the accelerator and you move on the clutch bite there is no juddering however if you move off using the accelorator the juddering happens again
Mr R.
  A special one.
Could just be the clutch plate needs bedding in a bit.
Year's ago I have a clutch and flywheel replaced on my wife's classic mini.
It did the same thing, so I just pulled away sort of riding the clutch a few times and it was fine after that.
I don't mean launch it at 7k btw
  Clio 200 full fat
ok so move of using just the bite a few times ? ill give that a try
Mr R.
  A special one.
Id bring the revs up and pull away riding the clutch.
But tbh without seeing the car its a hard one to diagnose.
