Hi Guys,
Ben is correct, you can unplug it and try it.
On mine, it made absolutely no discernable difference, that is worrying. I have hooked a multimeter to the unit and can see the signal being applied, it also appears to work at idle as forcing activation at idle caused tractor mode.
However, we have no proof that it is working correctly at the cam phasing device.
I must stress, this is one theory only.. it needs to be tested properly.
Rich, thanks for the offer, all 172 owners interested in this research.. could we arrange another mini rr day and we can arrange a series of pre-run tests, and then actual tests to perform on the rollers.
Also, can the 172 guys at the rr day at re let me know if their car is EU sourced or UK sourced as that may help if a common factor.
Joe.
