piper cams have a moderate road profile cam, nothing too wild, 265 degrees or so and about 10mm lift. Claimed 12 hp increase 1500-6500 rpm range. Or slightly more agressive cams at 286 degrees, 12mm lift and 2500-7000 rpm range. Views?
not sure m8, i rang kent cams ages ago...they dont do them for the mk2 172, they said they would jus shave a bit off mine to give a higher lift cam, but then im not knowledgable in these matters.
