172 throttle body?
do you want to get rid of the inlet manifold and have 4 seperate throttle bodies (one for each cylinder) or just get a throttle bigger that is bigger than your current one?
You do know if you put a bigger throttle body on and then get it remapped you will lose bottom end power but will gain top end. at least that is what i have experianced in other cars anyway!
No doubt someone has done it on here and will be able to help you!
Theres not really much room to play with on the plenum side anyway.
The only upgrade I can think of is replacing the drive by wire one with a propper one ;)
Would improve throttle response but wont give you more power, have a search for BenR's cnc manifold matching service which is a choice mod and would give better gains than a larger throttle body since the head to manifold join is the worst part of the intake system.
