I'm not too sure tbh mateThere's a fair few MK3s running 400+lbsft on the PK4 box but I wonder if they changed the internals on them?
And when they finally do get it right, everyone complainsIf there's one thing Renault never manage to get right it's a bloody gearbox š
Nah those are shite toošš Fine if you want a standard car but 9f you want to map it then you're out of luck
Loved mine! Best Clio RS of the lot!!Nah those are shite toošš Fine if you want a standard car but 9f you want to map it then you're out of luck
A lot have said that, I'd love to have an auto to blast about in too!Loved mine! Best Clio RS of the lot!!
It took me about a month to gel with it then it just seemed to all fall into place and I found it just as focused as any Clio before it when you were on it and as civilised as a golf around townA lot have said that, I'd love to have an auto to blast about in too!
I'm sick of getting them rebuilt tbhš My mate loves me because its a never ending stream of money because everyone I know gets sent thereššAināt that the truth.
Every renault Iāve tried the gearbox is awful, they really should have packed it in an gone to zee Germans for em.
Does a JC5 handle the power? lets say u turbo it with a meg gasket. And low boostThe PK4 box is about 80kg with fluid, whereas a JC5 is about 40kg with fluid. My megane has a PK4 and lifting one of those onto a gearbox jack alone is enough to put me off š
It does, just not for very long. Expect to change the box with every oil change š¤£
Did u finish the build bud ?Late reply to this thread. I am in the process of putting a 265 motor in, I decided it would be easier to use the megane 2 box instead of the pk box. I didnt weight them but the 225 box is definitely lighter. The only issue I am having is fitting the clio 2 top engine mount to the 265 engine with out modifying the timing belt cover of the meg 3 motor
I spoke to a specialist here in South Africa that has a 225 converted 182, and amazingly he told me he's got a VW 6-speed box in it, precisely because the Renault boxes are shite š . I wish I had pics/more info, but for now that's all I know.Aināt that the truth.
Quite a few vw 02m gearbox conversions done over here on the higher powered 172/182 conversions. Can get an adaptor plate and flywheel to suit from Efiparts.I spoke to a specialist here in South Africa that has a 225 converted 182, and amazingly he told me he's got a VW 6-speed box in it, precisely because the Renault boxes are shite š . I wish I had pics/more info, but for now that's all I know.
